Compiler/TMS320F28335: Problem with C-Library function memcpy
Part Number: TMS320F28335
I am seeing a odd issue when using memcpy routine, from <string.h> standard c library.  I am trying to copy data from one array to another, whose types are uint32_t .  I am seeing that if i use memcpy to do this, as below  it only copies half the array.
static uint32_t vehicle_key[8] = {0x55555555U, 0x55555555U, 0x55555555U, 0x55555555U, 0x55555555U, 0x55555555U, 0x55555555U, 0x55555555U};
memcpy(vehicle_key_dest, vehicle_key, 8);
But, if i do it by using a for loop (as shown below), then it works as expected.
for ( i = 0; i < 8; i++ )
   vehicle_key_dest[i] = vehicle_key[i];
Does anyone know why i would be seeing different behavior from these functions?
    memcpy() size argument specifies memory size, not array length. You need to use sizeof() operator to get size of specific object:
    memcpy(vehicle_key_dest, vehicle_key, sizeof(vehicle_key_dest));
    or if extern declaration of vehicle_key_dest doesn't specify array length, then perhaps this way
    memcpy(vehicle_key_dest, vehicle_key, sizeof(vehicle_key_dest[0]) * 8);
    Edward
  • ah, i should have none that. Thanks for quick response
