Hello everybody,
is there an assembler code example for nested interrupts ?
Thanks in advance, Jan
Hello everybody,
Hi Jan,
Thanks for your question! While we do not have nested interrupt examples written directly in assembly language, we do have nested interrupt examples in C2000Ware using driverlib functions. We also have an "assembly viewer" of sorts built into Code Composer Studio. You can use these together to get an idea of the assembly that is generated for the nested interrupts. Once you go into debug mode on an example project, you can view the assembly code being executed by opening the Disassembly tab (go to View->Disassembly in Code Composer Studio).
While this does not provide an assembly file, it can give you an idea of the assembly operations executed during the nested interrupts.
Let me know if this answers your question!
Vince
If I was able to answer your question, please press the green "Verify" button below, thanks!
Hi Vince,
thank you for your answer.
This is an interesting approach. I will try it out.
Regards, Jan
Hi Jan,
Sounds good, let us know if we can assist you in your testing!
Vince
If I was able to answer your question, please press the green "Verified" button below, thanks!
