Part Number: TMS320F28379D
float CLAasinTable[]={
0.0, 1.0, 0.0,
0.000000636202, 0.999877862610, 0.007815361896,
0.000005099694, 0.999510644409, 0.015647916155,
0.000017268312, 0.998895919094, 0.023514960332,
0.000041121765, 0.998029615282, 0.031434003631,
0.000080794520, 0.996905974725, 0.039422875916,
0.000140631089, 0.995517492804, 0.047499840611,
0.000225244584, 0.993854840311, 0.055683712914,
0.000339579512, 0.991906765146, 0.063993984848,
0.000488979852, 0.989659972212, 0.072450958820,
0.000679263611, 0.987098979366, 0.081075891529,
0.000916805182, 0.984205946802, 0.089891150305,
0.001208627040, 0.980960476685, 0.098920384204,
0.001562502549, 0.977339379243, 0.108188712551,
0.001987071928, 0.973316400729, 0.117722933997,
0.002491973784, 0.968861907789, 0.127551759665,
0.003087995053, 0.963942521723, 0.137706074532,
0.003787242692, 0.958520694794, 0.148219231941,
0.004603341138, 0.952554219267, 0.159127386977,
0.005551660294, 0.945995657913, 0.170469875522,
0.006649579796, 0.938791682505, 0.182289647088,
0.007916796475, 0.930882303984, 0.194633761132,
0.009375683410, 0.922199974574, 0.207553958472,
0.011051710808, 0.912668537890, 0.221107321885,
0.012973941175, 0.902201997769, 0.235357042896,
0.015175614174, 0.890703070035, 0.250373315541,
0.017694840102, 0.878061473098, 0.266234382514,
0.020575425537, 0.864151902887, 0.283027765009,
0.023867860513, 0.848831624374, 0.300851714968,
0.027630504055, 0.831937595031, 0.319816937941,
0.031931014547, 0.813283013821, 0.340048646894,
0.036848083955, 0.792653161200, 0.361689022958,
0.042473551274, 0.769800358920, 0.384900179460,
0.048914992206, 0.744437830278, 0.409867752228,
0.056298910750, 0.716232177740, 0.436805274317,
0.064774696786, 0.684794109766, 0.465959540059,
0.074519565699, 0.649666934178, 0.497617226179,
0.085744766889, 0.610312179660, 0.532113122767,
0.098703445606, 0.566091493186, 0.569840443472,
0.113700678529, 0.516243664372, 0.611263845480,
0.131106395009, 0.459855210927, 0.656936015611,
0.151372169232, 0.395822366759, 0.707518998893,
0.175053263659, 0.322801460177, 0.763811905770,
0.202837883870, 0.239143420888, 0.826787304376,
0.235586468765, 0.142806299514, 0.897639596948,
0.274385149825, 0.031236880585, 0.977850174820,
0.320619535938, -0.098791845166, 1.069276441800,
0.376078169620, -0.251407364538, 1.174275392129,
0.443100143614, -0.431959397725, 1.295878193174,
0.524789871827, -0.647485610469, 1.438041695773,
0.625336471263, -0.907400624736, 1.606018804842,
0.750500589935, -1.224540947101, 1.806917563896,
0.908377657341, -1.616794995066, 2.050569262035,
1.110633894185, -2.109729648039, 2.350920816737,
1.374584721437, -2.740985157716, 2.728353889708,
1.726848242753, -3.567962877198, 3.213722960014,
2.210117561056, -4.682006534082, 3.855770086891,
2.896554011854, -6.236312386687, 4.735651038017,
3.916505715382, -8.505488022524, 5.997790945975,
5.526855868703, -12.026617159136, 7.922628470498,
8.298197116322, -17.983705080358, 11.123941286820,
13.741706072449, -29.488929624542, 17.203344479111,
27.202707817485, -57.466598393615, 31.741016484669,
83.158101335898, -171.803399517566, 90.149831709374
float asin_expected[BUFFER_SIZE]={
1.570796, 1.393789, 1.320141, 1.263401, 1.215375,
1.172892, 1.134327, 1.098718, 1.065436, 1.034046,
1.004232, 0.9757544, 0.9484279, 0.9221048, 0.8966658,
0.8720123, 0.8480621, 0.8247454, 0.8020028, 0.7797828,
0.7580408, 0.7367374, 0.7158381, 0.6953120, 0.6751316,
0.6552721, 0.6357113, 0.6164289, 0.5974064, 0.5786270,
0.5600753, 0.5417370, 0.5235988, 0.5056486, 0.4878751,
0.4702678, 0.4528166, 0.4355124, 0.4183464, 0.4013104,
0.3843968, 0.3675981, 0.3509074, 0.3343180, 0.3178237,
0.3014185, 0.2850964, 0.2688521, 0.2526802, 0.2365756,
0.2205333, 0.2045484, 0.1886164, 0.1727327, 0.1568929,
0.1410927, 0.1253278, 0.1095943, 0.09388787, 0.07820469,
0.06254076, 0.04689218, 0.03125509, 0.01562564
void CLA_runTest(void)
int16_t i;
float error;
for(i = 0; i < BUFFER_SIZE; i++)
fVal= (float)(BUFFER_SIZE - i)/(float)BUFFER_SIZE;
CLA_forceTasks(CLA1_BASE,CLA_TASKFLAG_1);
WAITSTEP;
y[i] = fResult;
error = fabsf(asin_expected[i]-y[i]);
if(error < 0.1f)
Example_PassCount++;
else
Example_Fail++;
__interrupt void Cla1Task1 ( void )
//Local Variables
int xTblIdx; //integer valued Table index
float A0,A1,A2; //Table coefficients
float *entry;
float result;
//Preprocessing
__mdebugstop();
xTblIdx = fVal * TABLE_SIZE_M_1; //convert table index to u16-bits
xTblIdx = xTblIdx * 3; //Table is ordered as 3 32-bit coefficients, the
//index points to these triplets, hence the *3*sizeof(float)
entry = &CLAasinTable[xTblIdx];
A0 = *entry++;
A1 = *entry++;
A2 = *entry;
result = A0 + fVal*(A1 + A2*fVal);
//Post processing
if(fVal < 0)
result = - result;
fResult = result;
//Task 1 : Calculate asin(X)
// Description:
// Step(1): Calculate absolute of the input X
// Step(2): Use the upper 6-bits of input "X" value as an
// index into the table to obtain the coefficients
// for a second order equation:
// _FPUasinTable:
// CoeffA0[0]
// CoeffA1[0]
// CoeffA2[0]
// CoeffA0[63]
// CoeffA1[63]
// CoeffA2[63]
// Step(3): Calculate the angle using the following equation:
// arctan(Ratio) = A0 + A1*Ratio + A2*Ratio*Ratio
// arctan(Ratio) = A0 + Ratio(A1 + A2*Ratio)
// Step(4): The final angle is determined as follows:
// if( X < 0 )
// Angle = -Angle
2837xd routine "cla_ex1_asin" ,There are 64 groups that each have three parameters in the CLAasinTable. Do each group of parameters use the parameter values of the fitting curve generated by the regression analysis function coeff in MATLAB? A total of 64 groups, respectively, corresponding to the fitting parameters of arcsin curve. Then, the values of 64 arcsin are calculated by the curve equation represented by 64 groups of fitting parameters, and then compared with values of asin_expected. This routine is like this, right?
