Other Parts Discussed in Thread: CONTROLSUITE
is the PM_bissc library available also for F28379S?
Thank you,
Carlo
Thank you,
Carlo
Hi Carlo,
Unfortunately the individual best able to respond is unable to respond today. They should be able to respond more confidently by Thursday.
I assume you are referring to the library & example found within controlSUITE. If so, my understanding is that the same PM_bissC_Lib.lib should work with either F28379D or F28379S. You'd just need to tweak the project that calls the library to work with the F28379S (change linker command file, etc).
Thank you,
Brett
