Other Parts Discussed in Thread: CONTROLSUITE
Hallo! I appreciate for your kindly advice regarding
"THMDSHVMPPTKIT operation below input voltage range" for our research
1.Can this KIT(input voltage range is 200min-300Vmax) work at Vpv below 200V?
This is because we plan to use actual Solar module around 500W that has lower voltage such as 70-100V (example: use 2pcs of 200W panel (40V 6A ) in series?
We of course can accept power derating at below lower input voltage, 200V.
2. If yes, we'd like to try with 2*200W solar panes that has Vmp=40V, Imp=5A, 2 in series.
In this case, I expect KIT MPPT works at Vpv=80V (40*2) and Ipv=2 to 3Amps (limited by KIT) . Is this correct?
We guess, input current will be limited around 2 to 3Amps and output power from KIT will be about 80V*(2 to 3A) * efficiency=150 to 220W.
3. If not, we'd like to ask your advice for modification in software and hardware by our power electronics experts. Can we get support from TI experts?
Our experts are familiar with DC-DC conversion including safety in hardware and software and willing to try with our own responsibility.
Thank you for your support in advance.
K.Watanabe, President, Fourteen Power ltd.
