Help with EZ430-RF2560 ( Error[e117] )
I tried to build EZ430-RF2560 Bluetooth SDK with IAR 5.20 full 30 days.
Error[e117]: Incompatible runtime models. Module accelerometer_pl specifies that '__data_model' must be 'small', but module vendor_specific_script
has the value 'large'
Error while running Linker
How to fix it?
Thanks.
  • This problem is fixed but the new error is found.
    Fatal Error[e72]: Segment DATA20_Z must be defined in a segment definition option (-Z, -b or -P)
    How to fix it?
  • In reply to Paulo Tovo:
    Paulo,
        Did you modify the project settings?
    Rgds,
    Did you try to compile the workspace using an older version of the IAR Workbench before? It messes up the settings.
    Just reinstall the EZ430-RF2560 SDK and compile with IAR Workbench 5.20.
