Tool/software: TI-RTOS
While reviewing the TMS320F28069 Silicon Errata (sprz342k), I saw the usage note 4.1.1 "PIE: Spurious Nested Interrupt After Back-to-Back PIEACK Write and Manual CPU Interrupt Mask Clear". I'm using TI-RTOS, which means that the TI-RTOS kernel is responsible for acknowledging the PIE. I assume that kernel has this fix, but I was wondering are there were versions of TI-RTOS kernel with this fix? If so, in which version of TI-RTOS was it fixed? It would be helpful to know when the fix was introduced to check if an existing application is using a versions with or without the fix.
Joseph
