In reference to SafeTI Diagnostic Library and code generated by HalCoGen, in safety applications should we use het1ParityCheck() or SL_SelfTest_HET(HET_SRAM_PARITY_TEST,SL_HET1,0U,0U); ?
In the example of usage SafeTI diagnostic library in boot time (sys_startup.c) het1ParityCheck() is being called but in main() SL_SelfTest_HET() is being used.
The question also applies to other peripheries where the situation is the same.
