If i directly get the code generated by EMDC for EVM430I2040S then is it any changes to be made in or i can burn it blunt to board.
Also in case of reducing the stack size 128 is ok for same and how can i do the same ?
Thanks in advance
Thanks in advance
Hi Gautam,
Do not suggest you reduce the stack size. If you want to reduce your code size suggest you could try delete the communication part with GUI or setting the optimization level File->Properties-> Optimization
