Hello, we are trying to debug the capture timer, using the 16Mhz SMCLK configuration, currently we need to capture the low-level duration of the us level.
But there are currently the following two questions, I would like to ask you to help confirm them:
1. Whether the relevant configuration of CS (sys_cs_init) is normal, especially the CS_MCLK_FLLREF_RATIO parameter in the code.
2. Whether the calculation method of elapsedTime in the capture interrupt is correct, the unit is us.PUMA-MCU-test.zip
