isn't 9600/8N1 the default BSL setting?
However, the BSL doe snot provide any UI to change the baudrate at will. It only accepts its default setting on startup, and onyl a few newer BSL incarnations allow switching to a different baudrate (57600/8N1).
If you want something else right from the start, you'll need to write your own BSL, which is not a trivial job, and is only possible at all on the newest devices with rewritable (flash based) BSL.
