Hi experts,
My customer wants to check if the ROM area of MSP430FR2676 is corrupted.
Is it possible to verify check the data in this ROM area?
Please tell me how to check the data in this ROM area.
Sasaki
Hi experts,
Sasaki
Hi Sasaki,
Why this customer need verfication this data in ROM.
As you know, this data is store in ROM in factory and can't write, thus this should not be corrupted.
Is there are some issue for this area data?
Thanks!
Best Regards
Johnson
Hi Johnson-san,
Thank you for the reply.
The customers want to prevent the MSP430 from malfunctioning when the ROM data is corrupted. Therefore, they want to check if the ROM data is correct.
It is similar to functional safety.
Is there a way to check the ROM data?
Sasaki
Hi Sasaki,
There are no method to verfication those data in ROM, we don't open those data that burned into ROM.
If you are encounter some issue about this, maybe we can discussion case by case.
Thanks!
Best Regards
Johnson
Hi Johnson-san,
Thank you for the information.
I think it is possible to verify the data if ROM Lib can be written to FRAM.
Is there a ROM Lib CCS project? I want to use it to write ROM Lib to FRAM and verify the data.
Sasaki
Hi Sasaki,
We don't have example to read ROM data, but maybe you can refer to this FRAM example code:
https://dev.ti.com/tirex/explore/node?node=AJu.JUAI4WJeaw9uXA2QHA__IOGqZri__LATEST
Attach the memory map for FR2676:
Thanks!
Best Regards
Johnson
Hi Sasaki,
We don't share this source code, maybe you can try to read more device and do some compare.
Thanks!
Best Regards
Johnson
Hi Sasaki-san,
I think we should have checksum data, but we don't have more information about ROM data.
Thanks!
Best Regards
Johnson
