Hi!
I'm working on a project based around the MSP430AFE252 mcu. I'm using a LaunchPad to program and debug the application. In my app there is a timer interrupt. My problem is that the debugger never stops at the breakpoint placed in the timer ISR. I tried both IAR and CCS with the same results. I tested the issue with an example timer A code from TI and found that the circuit is working so there must be something with the debugger. When the circuit is running alone I can see the interrupts firing and my ISR toggles a LED. When in debug mode the circuit doesn't fire any interrupts thus never hits my breakpoint in the ISR.
Any idea would be great. Thank you!
