This is a particular bugbear of mine...
Examples are supposed to be exemplars of good practice - they should be clean, well documented and hopefully, correct; the comments should be appropriate and not misleading...
Consider the following I2C example ISR from eusci_b_i2c_ex5_masterMultipleSlave.c:
void USCIB0_ISR(void) { switch(__even_in_range(UCB0IV,0x1E)) { case 0x00: break; // Vector 0: No interrupts break; case 0x02: break; case 0x04: EUSCI_B_I2C_masterSendStart(EUSCI_B0_BASE); break; // Vector 4: NACKIFG break; case 0x06: break; // Vector 6: STTIFG break; case 0x08: break; // Vector 8: STPIFG break; case 0x0a: break; // Vector 10: RXIFG3 break; case 0x0c: break; // Vector 14: TXIFG3 break; case 0x0e: break; // Vector 16: RXIFG2 break; case 0x10: break; // Vector 18: TXIFG2 break; case 0x12: break; // Vector 20: RXIFG1 break; case 0x14: break; // Vector 22: TXIFG1 break; case 0x16: break; // Vector 24: RXIFG0 break; case 0x18: if(TXByteCtr) // Check TX byte counter { EUSCI_B_I2C_masterSendMultiByteNext(EUSCI_B0_BASE, TXData[SlaveFlag]); TXByteCtr--; // Decrement TX byte counter } else { EUSCI_B_I2C_masterSendMultiByteStop(EUSCI_B0_BASE); __bic_SR_register_on_exit(CPUOFF); // Exit LPM0 } break; // Vector 26: TXIFG0 break; default: break; } }
The two main things here are that
- The comments regarding the vector labels are out of sync/wrong,
- This is supposed to be an exemplar of driverlib coding- why aren't the "magic" literals replaced by their symbolic equivalents? All the correct (hopefully) symbolic names are in the driverlib headers, surely they should be used....
e.g. (not an exemplar - just cut-n-pasted from a project I'm working on):
DECLARE_ISR(USCI_B0_VECTOR, USCIB0_ISR) { // These are the I2C definitions for the UCSI switch( __even_in_range( UCB0IV, USCI_I2C_UCBIT9IFG ) ) { case USCI_NONE: // No interrupt break; case USCI_I2C_UCALIFG: // Arbitration lost - UCALIFG break; case USCI_I2C_UCNACKIFG: // NAK received (Master only) // EUSCI_B_I2C_masterSendStart( EUSCI_B0_BASE ); // Resend START if NAK'd break; case USCI_I2C_UCSTTIFG: // START condition detected with own address (Slave mode only) break; case USCI_I2C_UCSTPIFG: // STOP condition detected (Master & Slave mode) break; case USCI_I2C_UCRXIFG3: // RXIFG3 break; case USCI_I2C_UCTXIFG3: // TXIFG3 break; case USCI_I2C_UCRXIFG2: // RXIFG2 break; case USCI_I2C_UCTXIFG2: // TXIFG2 break; case USCI_I2C_UCRXIFG1: // RXIFG1 break; case USCI_I2C_UCTXIFG1: // TXIFG1 break; case USCI_I2C_UCRXIFG0: // RXIFG0 break; case USCI_I2C_UCTXIFG0: // TXIFG0 break; case USCI_I2C_UCBCNTIFG: // Byte count limit reached (UCBxTBCNT) break; case USCI_I2C_UCCLTOIFG: // Clock low timeout - clock held low too long break; case USCI_I2C_UCBIT9IFG: // Generated on 9th bit of a transmit (for debugging) break; } }
