CCS/MSP430FR5994: Hanning window for FFT with MSP430 LEA module
Part Number: MSP430FR5994
I would like to ask your help on a problem I had stuck with:
I would like to use Hanning window in my own FFT application. In the FFT example source of DSP library, I only found example for the Hamming window and the documentation I had found was not detailed enough to learn from it what I need to know.
Is the initHamming() fucntion modifiable to take Hanning form?
Is there any concrete example you aware of, in which MSP430 LEA modul used for a realtime frequency filtering ? (time domain - window - FFT- spectrum modification - iFFT - signal building (overlap) time domain)
Thank you for your help,
Laszlo
  • Hi Laszlo,
    I'm not sure I fully understand your question but yes the initHamming() function can be modified to best fit the needs of your application. Here are some resources I find helpful when trying to understand the purpose of a hamming window:
    There are several examples available that showcase the capability of the LEA when performing an FFT:
    I'd also like to direct you to the DSPLIB User's Guide which provides a lot of very useful information on how to use LEA as well as it's limitation and supported API's. Let me know if you have any further questions.
    Caleb Overbay
