MSP430FR5730: How to reduce power consumption in LPM4
Part Number: MSP430FR5730
I try to further reduce the power consumption in LPM4 in my MSP430FR5730 design.
I can't use LPM4.5, because the wake up source is Timer A0 clocked from an external ultra low power oscillator.
At the moment, I'm using the slac491i example for LPM4:
  P1DIR = 0;
  P1OUT = 0;
  P1REN = 0xFF;
  P2DIR = 0;
  P2OUT = 0;
  P2REN = 0xFF;
  CSCTL0_H = 0xA5;
  CSCTL1 |= DCOFSEL0 + DCOFSEL1;             // Set max. DCO setting
  CSCTL2 = SELA_1 + SELS_3 + SELM_3;        // set ACLK = VLO; MCLK = DCO
  CSCTL3 = DIVA_0 + DIVS_1 + DIVM_1;        // set all dividers
  CSCTL4 = XT1OFF + XT2OFF;
  CSCTL5 &= ~(XT1OFFG + XT2OFFG);
  REFCTL0 |= REFTCOFF;
  REFCTL0 &= ~REFON;
  __bis_SR_register(LPM4_bits);
Is there a clever way to save more power?
Kind regards
Gerd
  • General considerations for low power:
    * All clocks (including MCLK) should be set to the lowest possible frequency.
    * All unused modules should be turned off.
    * All unused I/Os should be put to output direction with low output.
    I hope this will help.
  • Hi Mike,
    Thanks a lot.
    I'll try that.
    In the mean time I found the major problem in my code.
    Because of re-initialization of the ports in an other function unintentionally I created floating inputs.
    I was not aware, that this can easy double the power consumption.
    Kind regards
    Gerd
