Hello readers!
I try to understand how to use the UCS-FLL. Therefore I am using the mentioned TI sample code above on a MSP430F5529.
I am using a MSP-TS430PN80USB with the following quartzes: XT2 = 1MHz (as delivered), XT1 = 32768Hz (XCAP_2, with no external capacitors).
The comments within the code are explaining that
- LFXT1 = 32768Hz --> ACLK
- LFXT1 --> FLL (default) --> MCLK = 32 * ACLK
- HFXT2 --> SMCLK
But my oscilloscope shows me:
- ACLK = 32768Hz, Pin1.0 (21) --> correct according to the comments
- MCLK = 1.0xMHz, Pin7.7 (60) --> could be correct according to the comments if 1.0xMHz = 220Hz
- SMCLK = about 4MHz, Pin2.2 (31) --> ???
What I don't understand (according to the comments):
- Why can I read on my oscilloscope that there are 4MHz at Pin2.2 if I am using a 1MHz-quartz as XT2?
Assumptions:
- Possibility 1: 216Hz = XT1 --> FLL --> MCLK = 222Hz and SMCLK = ??? *) N = 7
- Possibility 2 : MCLK = 1MHz and 216Hz --> FLL --> SMCLK *) N = 0
*) As I do not know by sure which default FLLN has got I used the formula
fDCOCLK = D * (N + 1) * (FFLLREFCK / n) [from users guide p.93, chapter 4.2.6], where N belongs to FLLN,
to find out what N should be. You can find the answers of my calculations within the assumptions above.
Questions:
- Can anybody confirm that Possibility 2 is right or just put my nose into the right direction?
- I suppose that the default of FLLN = 0 which means N =1. Is this right?
Many thanks in advance!
