MSP430F5131: How to generate two 400khz clock with 180° phase shift by MSP430?
Part Number: MSP430F5131
Hi MSP430 Expert,
I want to generate two 400khz clock with 180° phase shift by MSP430, high volatge of the clock is 5V, low voltage is 0V. could you please recommend a device and give me code tutorial ?
Kevin
  • Hi Kevin,
    This is all the MSP430 that support 5V I/O.
    This is the code you can refer to.
    MSP430F51x2_ta0_16.c
    /* --COPYRIGHT--,BSD_EX
     * Copyright (c) 2012, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *                       MSP430 CODE EXAMPLE DISCLAIMER
     * MSP430 code examples are self-contained low-level programs that typically
     * demonstrate a single peripheral function or device feature in a highly
     * concise manner. For this the code may rely on the device's power-on default
     * register values and settings such as the clock configuration and care must
     * be taken when combining code from several examples to avoid potential side
     * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
     * for an API functional library-approach to peripheral configuration.
     * --/COPYRIGHT--*/
    //  MSP430F51x2 Demo - Timer0_A3, PWM TA0.1-2, Up Mode, DCO SMCLK
    //  Description: This program generates two PWM outputs on P3.6,P3.7 using
    //  Timer0_A configured for up mode. The value in CCR0, 512-1, defines the PWM
    //  period and the values in CCR1 and CCR2 the PWM duty cycles. Using ~1.045MHz
    //  SMCLK as TACLK, the timer period is ~500us with a 75% duty cycle on P3.6
    //  and 25% on P3.5
    //  ACLK = n/a, SMCLK = MCLK = TACLK = default DCO ~1.045MHz.
    //                MSP430F51x2
    //         --|RST                |
    //           |      P3.6/PM_TA0.1|--> CCR1 - 75% PWM
    //           |      P3.5/PM_TA0.2|--> CCR2 - 25% PWM
    //  B. Nisarga
    //  Texas Instruments Inc.
    //  Dec 2009
    //  Built with CCS v4 and IAR Embedded Workbench Version: 4.21
    #include <msp430.h>
    int main(void)
      WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
      P3DIR |= BIT6+BIT5;                       // P3.6 and P3.5 output
      P3SEL |= BIT6+BIT5;                       // P3.6 and P3.5 options select
      // Configure TA0
      TA0CCR0 = 512-1;                          // PWM Period
      TA0CCTL1 = OUTMOD_7;                      // CCR1 reset/set
      TA0CCR1 = 384;                            // CCR1 PWM duty cycle
      TA0CCTL2 = OUTMOD_7;                      // CCR2 reset/set
      TA0CCR2 = 128;                            // CCR2 PWM duty cycle
      TA0CTL = TASSEL_2 + MC_1 + TACLR;         // SMCLK, up mode, clear TAR
      __bis_SR_register(LPM0_bits);             // Enter LPM0
      __no_operation();                         // For debugger
    Eason
