Dear team,
My customer want to measure the frequency of ext signal with timer capture mode.
Hardware: MSP-FET430U80 with FG439
XT1=32.768kHz XT2=4MHz
Code:
#include <msp430fg439.h> #include "main.h" unsigned long SMCLK_Count_Num = 0; unsigned long Frequency = 0; unsigned char Count = 0x0; unsigned int REdge1, REdge2; void main(void) { WDTCTL = WDTPW | WDTHOLD; // stop watchdog timer SetupClock(); Capture_Pos(); // __enable_interrupt(); while(1) { // __enable_interrupt(); __bis_SR_register(LPM0_bits + GIE); // Enter LPM0 __no_operation(); // For debugger if (TB0CCTL1 & COV) // Check for Capture Overflow while(1); SMCLK_Count_Num = REdge2 - REdge1; Frequency = (Count*SMCLK_Frequency)/SMCLK_Count_Num; // TBCTL |= TBCLR + TBIE; // TBCCTL1 |= CCIE; } } void SetupClock() { uint16_t tmpv; FLL_CTL1 &= ~XT2OFF; do { IFG1 &= ~OFIFG; for (tmpv = 0xff; tmpv > 0; tmpv--); } while((IFG1 & OFIFG)!=0); IFG1 &= ~OFIFG; FLL_CTL1 |= SELM_XT2+SELS; } void Capture_Pos() { P2SEL |= BIT2; P2DIR &= ~BIT2; TB0CTL |= TBSSEL_2 + MC_2 + TBCLR ; TBCCTL1 = CM_1+ CCIS_1 + SCS + CAP + CCIE; } #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__) #pragma vector = TIMERB1_VECTOR __interrupt void TIMER0_B1_ISR (void) #elif defined(__GNUC__) void __attribute__ ((interrupt(TIMER0_B1_VECTOR))) TIMER0_B1_ISR (void) #else #error Compiler not supported! #endif //__interrupt void Timer_B1 (void) { switch(__even_in_range(TB0IV,0x0A)) { case TB0IV_NONE: break; case TB0IV_TBCCR1: if (!Count) { REdge1 = TB0CCR1; Count++; } else { REdge2 = TB0CCR1; Count=0x0; // TBCTL &= ~TBIE; // TBCCTL1 &=~CCIE; __bic_SR_register_on_exit(LPM0_bits + GIE); // Exit LPM0 on return to main } break; case TB0IV_TBCCR2: break; case TBIV_3: break; case TBIV_4: break; case TBIV_5: break; case TBIV_6: break; case TB0IV_TBIFG: break; default: break; } }
It hangs in
while(1);
They want to measure 80KHz ext singal.
