I'm trying to port SLAA766 for MSP430FR2000 Example for controlling RGB LED over UART over to the MSP430FR2311. I've made the changes suggested in SLAA812, by:
1. changing the timer to TIMER1_B
2. changing the pins for PWM to P1.0, P2.0, P2.1
Now when I execute the below code, it always throws me into an unhandled interrupt / ISR Trap. What seems to be the issue?
#include<msp430.h> #include<stdint.h> // Contains the low (on) period for the RGB LEDs for each color selection const uint8_t colorsLow[12][3] = { //{R, G, B} {134,1,1}, //RED {134,15,1}, //RED-ORANGE {134,20,1}, //ORANGE {134,30,1}, //ORANGE-YELLOW {134,55,1}, //YELLOW {67,80,1}, //YELLOW-GREEN {1,134,1}, //GREEN {1,134,134}, //GREEN-BLUE {1,1,134}, //BLUE {67,1,134}, //BLUE-PURPLE {134,1,134}, //PURPLE {134,1,80} //PURPLE-RED }; // Contains the high (off) period for the RGB LEDs for each color selection const uint8_t colorsHigh[12][3] = { //{R, G, B} {1,134,134}, //RED {1,120,134}, //RED-ORANGE {1,115,134}, //ORANGE {1,100,134}, //ORANGE-YELLOW {1,80,134}, //YELLOW {68,55,134}, //YELLOW-GREEN {134,1,134}, //GREEN {134,1,1}, //GREEN-BLUE {134,134,1}, //BLUE {68,134,1}, //BLUE-PURPLE {1,134,1}, //PURPLE {1,134,55} //PURPLE-RED }; uint8_t selected; //Used to track the current color selection /** * main.c */ void main(void) { WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer selected = 0; // Default to Red // Configure UART // From user's Guide Table of Baud Rates, 9600 baud at BRCLK = 32768 // UCOS16 = 0 // UCBRx = 3 // UCBRFx = 0 // UCBRSx = 0x92 UCA0CTLW0 = UCSWRST | UCSSEL__ACLK; UCA0BRW = 3; UCA0MCTLW = 0x9200; UCA0CTLW0 &= ~UCSWRST; // Initialize eUSCI UCA0IE = UCRXIE; // Enable USCI_A0 RX interrupt // Configure GPIO // PASEL0 = BIT6 | BIT7 | BIT8 | BIT9; // TB0.1 and 0.2, UCA0 RXD and TXD // PADIR = BIT8 | BIT9 | BIT0; // TB0.1, 0.2, 0.0 (on P1.0) // PAOUT = 0; P1SEL0 = BIT6 + BIT7; // Enable UART function on p1.6 & 1.7 P1DIR = BIT0; // Set P1.0 to output P2SEL0 = BIT0 + BIT1; // Enable secondary function of TB1 output on given pins P2DIR = BIT0 + BIT1; // Enable output on p2.0 & 2.1 PAOUT = 0; // shut everything PM5CTL0 &= ~LOCKLPM5; // Disable the GPIO power-on default // high-impedance mode to activate // previously configured port settings // Set up Timer B in continuous mode for multiple time base PWMs. // See app note SLAA513 for theory. TB1CCTL0 = CCIS_0 + OUTMOD_4 + CCIE; // CCR0 toggle, interrupt enabled TB1CCTL1 = CCIS_0 + OUTMOD_4 + CCIE; // CCR1 toggle, interrupt enabled TB1CCTL2 = CCIS_0 + OUTMOD_4 + CCIE; // CCR2 toggle, interrupt enabled // REF0CLK/4 = 8192 is used for TBCLK so that the period of 60Hz can be // generated with TB0CCRx values totaling only 135 for the period of 60Hz // PWM. This is less than 255, so that the lookup table can be made of 8-bit // values, saving additional FRAM space on small devices. TB1CTL = TBSSEL__ACLK + ID__4 + MC_2 + TBCLR; // ACLK, contmode, clear TAR __bis_SR_register(LPM3_bits | GIE); // Go to LPM3 with interrupts __no_operation(); } // UART interrupt service routine #pragma vector=USCI_A0_VECTOR __interrupt void USCI_A0_ISR(void) { selected = UCA0RXBUF; // Get new value for selected color if(selected > 11) // If value out of range, set default 0 (red) { selected = 0; } } // Timer_B0 interrupt service routine #pragma vector=TIMER1_B0_VECTOR __interrupt void TIMER1_B0_ISR (void) { if(P1OUT & BIT0) // Check current output level { TB1CCR0 += colorsLow[selected][2]; // Low period (Blue LED on) P1OUT = 0; // TB0.0 not brought out on pin, so set manually } else { TB1CCR0 += colorsHigh[selected][2]; // High period (Blue LED off) P1OUT = BIT0; // TB0.0 not brought out on pin, so set manually } } // Timer_B1 Interrupt Vector (TBIV) handler #pragma vector=TIMER1_B1_VECTOR __interrupt void TIMER1_B1_ISR(void) { switch(__even_in_range(TB1IV,14)) { case 0: break; case 2: if(TB1CCTL1 & CCI) // Check current timer pin state { TB1CCR1 += colorsHigh[selected][0]; // High period (Red off) } else { TB1CCR1 += colorsLow[selected][0]; // Low period (Red on) } break; case 4: if(TB1CCTL2 & CCI) // Check current timer pin state { TB1CCR2 += colorsHigh[selected][1]; // High (Green off) } else { TB1CCR2 += colorsLow[selected][1]; // Low period (Green on) } break; default: break; } }
