MSP430FR2522: Captivate Noise Threshold
Part Number: MSP430FR2522
Dear MSP430 team,
my customer designs with MSP430FR2252 and he wants to read out the noise detected status flag.
Do you have a recommended procedure for this?
Can you provide some example software?
Thanks and best regards,
Joe
    Noise flag is here, belong to tElement.
    //! The noise detected flag indicates that noise was found on the channel.
    bool bNoiseDetected : 1;
    I think you can also use this function instead:
    NoiseLevel = CAPT_getGlobalFilteredNoiseLevel();
    Eason
  • Hallo Eason,
    have you got any software example how i can use the bNoiseDetected flag in combination with an callback?
    My own example code does not work, because of the flag ist not in the struct.
    Greetings
    Markus
    void main(void)
    	// Initialize the MCU
    	// BSP_configureMCU() sets up the device IO and clocking
    	// The global interrupt enable is set to allow peripherals
    	// to wake the MCU.
    	WDTCTL = WDTPW | WDTHOLD;
    	BSP_configureMCU();
    	__bis_SR_register(GIE);
    	// Start the CapTIvate application
    	CAPT_appStart();
    	/* Adding Callbacks for pairing-button, proximity */
    	MAP_CAPT_registerCallback(&Proximity, &my_proximity_callback);
    	// Background Loop
    	while(1)
    	    CAPT_appHandler();
    		// This is a great place to add in any
    		// background application code.
    		__no_operation();
    		// End of background loop iteration
    		// Go to sleep if there is nothing left to do
    		CAPT_appSleep();
    	} // End background loop
    } // End main()
    void my_proximity_callback(tSensor* pSensor)
        if(pSensor->bNoiseDetected == true)
            LED1_ON;
            __delay_cycles(5000);
            LED1_OFF;
            __delay_cycles(10000);
            LED1_ON;
            __delay_cycles(20000);
            LED1_OFF;
            LED1_ON;
            LED1_OFF;
        else
            if(pSensor->bSensorProx == true)
                LED1_ON;
            else
                LED1_OFF;
  • Here is an example:
    pSensor->pCycle[i]->pElements[j]->bNoiseDetected
    But I think it will be much easy if you use CAPT_getGlobalFilteredNoiseLevel();
