When a constant voltage is input to SD24_B from a regulated power supply and single conversion is executed,
if the conversion operation is performed multiple times, the result will fluctuate in the lower 4 bits in the high word 16 bits.
In this case, you can expect only the accuracy of the upper 12 bits, but how should you use it so that the value of 16 bits does not fluctuate?
