My team and I are currently trying to use our MCU to communicate with the BMP280 barometer via I2C. Right now when we run our code the data and clock line never are driven low. Are we missing something? Below is the code.
#include <msp430.h>
unsigned char TXData;
unsigned char TXByteCtr;
int main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P4SEL |= BIT1 + BIT2;
P4MAP1 = PM_UCB1SDA;
P4MAP2 = PM_UCB1SCL;
UCB1CTL1 |= UCSWRST; // Enable SW reset
UCB1CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
UCB1CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
UCB1BR0 = 12; // fSCL = SMCLK/12 = ~100kHz
UCB1BR1 = 0;
UCB1I2CSA = 0x77; // Slave Address is 77h
UCB1CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
UCB1IE |= UCTXIE; // Enable TX interrupt
TXData = 0x01; // Holds TX data
while (1)
TXByteCtr = 1; // Load TX byte counter
while (UCB1CTL1 & UCTXSTP); // Ensure stop condition got sent
UCB1CTL1 |= UCTR; // I2C TX, start condition
UCB1CTL1 |= UCTXSTT; // Transmit start
__bis_SR_register(GIE); // Enter LPM0 w/ interrupts
TXData++; // Increment data byte
// The USCIAB0_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count.
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector = USCI_B1_VECTOR
__interrupt void USCI_B1_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCI_B1_VECTOR))) USCI_B1_ISR (void)
#else
#error Compiler not supported!
#endif
switch(__even_in_range(UCB1IV,12))
case 0: break; // Vector 0: No interrupts
case 2: break; // Vector 2: ALIFG
case 4: break; // Vector 4: NACKIFG
case 6: break; // Vector 6: STTIFG
case 8: break; // Vector 8: STPIFG
case 10: break; // Vector 10: RXIFG
case 12: // Vector 12: TXIFG
if (TXByteCtr) // Check TX byte counter
UCB1TXBUF = TXData; // Load TX buffer
TXByteCtr--; // Decrement TX byte counter
else
UCB1CTL1 |= UCTXSTP; // I2C stop condition
UCB1IFG &= ~UCTXIFG; // Clear USCI_B0 TX int flag
__bic_SR_register_on_exit(LPM0_bits); // Exit LPM0
break;
default: break;
