Hi
I am using MSP-TS430PN80USB and target device F5525 to try BSL function. There is no problem when writing Flash by using BSL, such as 5529_LED_BLINK in slau319 code example. But when I use the BSL_scripter.exe to read out, it failed as the screenshot -- fail writingdata block starting at 00ff. I can see the read data from DOS command, but can’t output to a txt file. Have you experienced this before? If you know a solution, please kindly help to advise. Thanks.
My script is
MODE 5xx USB
TX_DATA_BLOCK 0x17f0 0x16 Data_Read_1.txt
