So this is my first time working with an f5529. I'm just trying to set up a basic UART Tx to the serial monitor for debugging. This is how I have my interrupt set up:
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCI_A0_VECTOR))) USCI_A0_ISR (void)
#else
#error Compiler not supported!
#endif
switch(__even_in_range(UCA0IV,4))
case 0: break; // Vector 0 - no interrupt
case 2: break; // Vector 2 - RXIFG
case 4: break; // Vector 4 - TXIFG
default: break;
I found it in some example code, so I figured that this would work, but whenever I try to compile, I get the error "'__even_in_range' was not declared in this scope". I wasn't getting the error the other day but now I am. Would it be because of the defines? I am using Energia as my platform.
