May I know is there any warranty for this MSP Gang programmer? I am facing some issue and suspecting the programmer is not working.
KH
KH
Hi KH,
There should be a sheet included in the MSP-GANG box with the tool that would detail any legal notices/disclaimers/warranty that may or may not exist for the tool (I do not know and you should consult the sheet for this information).
However, can you provide information about what is not working? I am hoping that we can help you through whatever issue you may be having. We will usually need to know a few things to diagnose an issue with using the MSP-GANG:
1. What you are trying to do vs. what behavior you are seeing? Are any error messages reported?
2. What firmware version is used, and what MSP-GANG hardware is used (you can get this by going to About > About in the GUI). I would generally recommend to use the latest version of the MSP-GANG software available on the web: www.ti.com/.../msp-gang. Right now the latest version is 1.2.8.0.
3. Additionally, you can have the GUI run a self-test on the MSP-GANG by using the GUI and going to Tools > Self Test. Attach results file if you see any failures.
4. Provide information about the JTAG/SBW connections between the MSP-GANG and your device, and any passives or other components on the JTAG/SBW lines on your device.
5. Your MSP-GANG GUI settings
Katie
Hi Katie,
Thanks for your prompt reply. The Error i saw from the programmer is Err 23. What does that mean? I will run a self test and update you asap.
KH
