There is not way to reset a micro due to some init error. Going through the debugging the function in autoinit.h function, system runs to BREAKPOINT_2 (See below), I press on run, but the system never goes back to the BREAKPINT_1, but it display an error in console
Console
Assertion failed, (!((*((volatile uint16_t *)((uint16_t)baseAddress + (0x0000)))) & (0x0002))), file ../driverlib/adc12_a.c, line 1
Code referenced above. What can I do?
/*****************************************************************************/ /* cinit */ /*****************************************************************************/ static __inline __attribute__((always_inline)) void run_cinit(void) { #if defined(__TI_EABI__) && \ defined(__MSP430__) && \ defined(__LARGE_CODE_MODEL__) && !defined(__LARGE_DATA_MODEL__) /*------------------------------------------------------------------------*/ /* Process the compressed ELF cinit table. The format is as follows: */ /* |4-byte load addr|4-byte run addr| */ /* |4-byte load addr|4-byte run addr| */ /* */ /* Processing steps: */ /* 1. Read load and run address. */ /* 2. Read one byte at load address, say idx. */ /* 3. Get pointer to handler at handler_start[idx] */ /* 4. call handler(load_addr + 1, run_addr) */ /*------------------------------------------------------------------------*/ if (__TI_Handler_Table_Base != __TI_Handler_Table_Limit) { unsigned long const *table_ptr = (unsigned long const *)__TI_CINIT_Base; unsigned long const *table_limit = (unsigned long const *)__TI_CINIT_Limit; while (table_ptr != table_limit) { unsigned long load_addr = *table_ptr++; unsigned long run_addr = *table_ptr++; unsigned char handler_idx = __data20_read_char(load_addr++); handler_fn_t handler = __TI_Handler_Table_Base[handler_idx]; handler(load_addr, run_addr); } } #elif defined(__TI_EABI__) || defined(__ARM_EABI__) /*------------------------------------------------------------------------*/ /* Process the compressed ELF cinit table. The format is as follows: */ /* |4-byte load addr|4-byte run addr| */ /* |4-byte load addr|4-byte run addr| */ /* */ /* Processing steps: */ /* 1. Read load and run address. */ /* 2. Read one byte at load address, say idx. */ /* 3. Get pointer to handler at handler_start[idx] */ /* 4. call handler(load_addr + 1, run_addr) */ /*------------------------------------------------------------------------*/ #if defined(__FROZEN__) /*------------------------------------------------------------------------*/ /* For C7X, use _symval() to force absolute addressing on these symbols, */ /* otherwise we will end up with an incorrect value if we rely on */ /* position-independent, PC-relative addressing. This is a temporary */ /* workaround. See Jira COMPILE-362 for more information. */ /*------------------------------------------------------------------------*/ if (_symval(__TI_Handler_Table_Base) != _symval(__TI_Handler_Table_Limit)) { char *const *table_ptr = (char *const *)_symval(__TI_CINIT_Base); char *const *table_limit = (char *const *)_symval(__TI_CINIT_Limit); #else if (__TI_Handler_Table_Base != __TI_Handler_Table_Limit) { char *const *table_ptr = __TI_CINIT_Base; char *const *table_limit = __TI_CINIT_Limit; #endif while (table_ptr != table_limit) // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< BREAKPOINT_1 { char const *load_addr = *table_ptr++; char *run_addr = *table_ptr++; char handler_idx = *load_addr++; handler_fn_t handler = __TI_Handler_Table_Base[handler_idx]; handler(load_addr, run_addr); // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< BREAKPOINT_2 } } #else /*------------------------------------------------------------------------*/ /* Process Cinit table for COFF. */ /*------------------------------------------------------------------------*/ #ifdef _TMS320C6X #define ALIGN_TYPE uintptr_t #define ALIGN_MASK 0x7 #elif defined(__MSP430__) #ifdef __LARGE_DATA_MODEL__ #define ALIGN_TYPE unsigned long #else #define ALIGN_TYPE unsigned #endif #define ALIGN_MASK 0x1 #else #define ALIGN_TYPE uintptr_t #define ALIGN_MASK 0x3 #endif #define ALIGN_PTR(ptr) \ ((unsigned const *)(((ALIGN_TYPE)ptr + ALIGN_MASK) & ~ALIGN_MASK)) unsigned const *recptr = (unsigned const *)__cinit__; int length; if (recptr != (unsigned *)-1) while ((length = *recptr++) != 0) { #if defined(__MSP430__) && defined(__LARGE_DATA_MODEL__) char *to = (void *)*(unsigned long const *)recptr; recptr += 2; #else char *to = (void *)*recptr++; #endif char *from = (void *)recptr; memcpy(to, from, length); from += length; recptr = ALIGN_PTR(from); } #endif }
