Hi friends!
I have modified the initial code about temperature sensor for read by ADC P8.4 a measurement of my conditioner.
It's run well.
Now, I need to read other two signals by the ports 8.5 and 8.6. Then I will operate similary that 8.4
I never have worked with ADC and I dont know the form I can do it.
Can you help me?
Thanks!
/* --COPYRIGHT--,BSD * Copyright (c) 2015, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ /******************************************************************************* * * TempSensorMode.c * * Simple thermometer application that uses the internal temperature sensor to * measure and display die temperature on the segmented LCD screen * * February 2015 * E. Chen * ******************************************************************************/ #include <driverlib.h> #include "TempSensorMode.h" #include "hal_LCD.h" #include <math.h> volatile unsigned char tempUnit = 0; // Temperature Unit signed long degC; // Celcius measurement signed long degF; // Fahrenheit measurement // TimerA UpMode Configuration Parameter Timer_A_initUpModeParam initUpParam_A1 = { TIMER_A_CLOCKSOURCE_ACLK, // ACLK Clock Source TIMER_A_CLOCKSOURCE_DIVIDER_1, // ACLK/1 = 32768Hz 0x2000, // Timer period TIMER_A_TAIE_INTERRUPT_DISABLE, // Disable Timer interrupt TIMER_A_CCIE_CCR0_INTERRUPT_DISABLE , // Disable CCR0 interrupt TIMER_A_DO_CLEAR // Clear value }; Timer_A_initCompareModeParam initCompParam = { TIMER_A_CAPTURECOMPARE_REGISTER_1, // Compare register 1 TIMER_A_CAPTURECOMPARE_INTERRUPT_DISABLE, // Disable Compare interrupt TIMER_A_OUTPUTMODE_RESET_SET, // Timer output mode 7 0x1000 // Compare value }; void tempSensor() { //Enter LPM3 mode with interrupts enabled while(mode == TEMPSENSOR_MODE) { __bis_SR_register(LPM3_bits | GIE); // LPM3 with interrupts enabled __no_operation(); // Only for debugger P8DIR |= BIT7; P8OUT |= BIT7; // P9OUT |= BIT7; // Turn LED2 On if (tempSensorRunning) { // Turn LED1 on when waking up to calculate temperature and update display P1OUT |= BIT0; // Calculate Temperature in degree C and F signed long temp = ADC12MEM0; degC = (484.8417005+(sqrt(1472.66038-0.09269042969*(long)temp))/-0.075932)*100; degF = (long)temp; // Update temperature on LCD displayTemp(); P1OUT &= ~BIT0; } } } void tempSensorModeInit() { tempSensorRunning = 1; displayScrollText("TEMPSENSOR MODE"); RTC_C_holdClock(RTC_C_BASE); // Stop stopwatch RTC_C_holdCounterPrescale(RTC_C_BASE, RTC_C_PRESCALE_0); // Select internal ref = 1.2V //CAMBIAMOS A 2.5V Ref_A_setReferenceVoltage(REF_A_BASE, REF_A_VREF2_5V); // Internal Reference ON Ref_A_enableReferenceVoltage(REF_A_BASE); // Enables the internal temperature sensor Ref_A_enableTempSensor(REF_A_BASE); while(!Ref_A_isVariableReferenceVoltageOutputReady(REF_A_BASE)); // Initialize the ADC12B Module /* * Base address of ADC12B Module * Use internal ADC12B bit as sample/hold signal to start conversion * USE MODOSC 5MHZ Digital Oscillator as clock source * Use default clock divider/pre-divider of 1 * Use Temperature Sensor internal channel */ ADC12_B_initParam initParam = {0}; P8SEL1 |= BIT4; //Set P8.4 as Analog Input, A7 P8SEL0 |= BIT4; P8SEL1 |= BIT5; //Set P8.5 as Analog Input, A6 P8SEL0 |= BIT5; P8SEL1 |= BIT6; //Set P8.6 as Analog Input, A5 P8SEL0 |= BIT6; initParam.sampleHoldSignalSourceSelect = ADC12_B_SAMPLEHOLDSOURCE_4; initParam.clockSourceSelect = ADC12_B_CLOCKSOURCE_ADC12OSC; initParam.clockSourceDivider = ADC12_B_CLOCKDIVIDER_1; initParam.clockSourcePredivider = ADC12_B_CLOCKPREDIVIDER__1; initParam.internalChannelMap = ADC12_B_NOINTCH; // Estaba esto ADC12_B_TEMPSENSEMAP ADC12_B_init(ADC12_B_BASE, &initParam); // Enable the ADC12B module ADC12_B_enable(ADC12_B_BASE); /* * Base address of ADC12B Module * For memory buffers 0-7 sample/hold for 256 clock cycles * For memory buffers 8-15 sample/hold for 4 clock cycles (default) * Disable Multiple Sampling */ ADC12_B_setupSamplingTimer(ADC12_B_BASE, ADC12_B_CYCLEHOLD_256_CYCLES, ADC12_B_CYCLEHOLD_4_CYCLES, ADC12_B_MULTIPLESAMPLESDISABLE); // Configure Memory Buffer /* * Base address of the ADC12B Module * Configure memory buffer 0 * Map input A30 to memory buffer 0 * Vref+ = VRef+ * Vref- = Vref- * Memory buffer 0 is the end of a sequence */ ADC12_B_configureMemoryParam configureMemoryParam = {0}; configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_0; configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A7; configureMemoryParam.refVoltageSourceSelect = ADC12_B_VREFPOS_INTBUF_VREFNEG_VSS; configureMemoryParam.endOfSequence = ADC12_B_ENDOFSEQUENCE; configureMemoryParam.windowComparatorSelect = ADC12_B_WINDOW_COMPARATOR_DISABLE; configureMemoryParam.differentialModeSelect = ADC12_B_DIFFERENTIAL_MODE_DISABLE; ADC12_B_configureMemory(ADC12_B_BASE, &configureMemoryParam); ADC12_B_clearInterrupt(ADC12_B_BASE, 0, ADC12_B_IFG0 ); // Enable memory buffer 0 interrupt ADC12_B_enableInterrupt(ADC12_B_BASE, ADC12_B_IE0, 0, 0); // Start ADC conversion ADC12_B_startConversion(ADC12_B_BASE, ADC12_B_START_AT_ADC12MEM0, ADC12_B_REPEATED_SINGLECHANNEL); // TimerA1.1 (125ms ON-period) - ADC conversion trigger signal Timer_A_initUpMode(TIMER_A1_BASE, &initUpParam_A1); // Initialize compare mode to generate PWM1 Timer_A_initCompareMode(TIMER_A1_BASE, &initCompParam); // Start timer A1 in up mode Timer_A_startCounter(TIMER_A1_BASE, TIMER_A_UP_MODE ); // Check if any button is pressed Timer_A_initUpMode(TIMER_A0_BASE, &initUpParam_A0); __bis_SR_register(LPM3_bits | GIE); // enter LPM3 __no_operation(); } void displayTemp() { clearLCD(); // Pick C or F depending on tempUnit state signed long deg; if (tempUnit == 0) { showChar('C',pos6); deg = degC; } else { showChar('V',pos6); deg = degF; } // Handle negative values if (deg < 0) { deg *= -1; // Negative sign LCDMEM[pos1+1] |= 0x04; //LCDMEM[pos1+1] |= 0x04; } // Handles displaying up to 999.9 degrees if (deg>=1000) showChar((deg/1000)%10 + '0',pos2); if (deg>=100) showChar((deg/100)%10 + '0',pos3); if (deg>=10) showChar((deg/10)%10 + '0',pos4); if (deg>=1) showChar((deg/1)%10 + '0',pos5); // Decimal point LCDMEM[pos3+1] |= 0x01; // Degree symbol LCDMEM[pos5+1] |= 0x04; }
