Part Number: TIRSLK-EVM-SW
I'm having issues with the tacho in the RSLK generating heaps of interrupts when the motor was spinning at full speed (main problem is slowing down my wifi connection through the cc3120) . I've partially solved it by using HwiP_setFunc to install a faster ISR. (overriding the CaptureMSP432_hwiIntFunction).
Is it possible/acceptable to install anything even lower level? I'm only incrementing a counter and storing the capture time (not using any ti-rtos routines).
I noticed in the stack in the HWI calls Hwi_dispatchC. Is it possible to override that just for these timer capture interrupts?
