Hi!
I saw the below white paper which shows explains how matched filter can be used to correct a noisy ADC wavelet signal against a reference signal:
"The convolution calculation in matched filter is the same as FIR with the reference signal patterns as the filter coefficients." I could not find any more implementation info.
1. Is this already implemented in the USS library?
2. How can I generate coefficients for the FIR filter using a reference signal?
Thanks in advance!
