Other Parts Discussed in Thread: MSP430FR2433, MSP-TS430RGE24A, MSP-FET, MSP-EXP430G2ET
I wrote firmware required for my application on the dev board for the micro. The dev board has too much stuff for my application. I need to make my own custom board which will be much smaller. I only need two components from the dev board. The micro and the USB connector. The links are below:
http://www.ti.com/lit/ds/slase59f/slase59f.pdf
I do see that the PC to the micro interface is via UART0. But how do I make the connections? Do I use the following connector:
I did find the schematic for the above component. I can incorporate it into my custom board. But is there a simpler way?
Thank you
Varun R
