PFA, SPI & I2C lines snapshot. I am planning to use 3 pin SPI mode with "P8.4/UCB1CLK/UCA1STE" configured in GPIO mode for CS control. Kindly let me know if its possible.
please see the details on the USCI features in the User's Guide and the SPI code examples in our Code Composer Studio's Resource Explorer.
Are you intending to use the MSP430 as SPI master? The MSP430 USCI STE functionality is limited to input direction. This means, if e.g. in multi-master mode the MSP needs to output an STE signal, this has to be done by any of the available GPIOs and CPU activity.
Best regards
Peter
I want to know, if I am using MSP430F5659 as a master in SPI 3 pin mode, can I use this "P8.4/UCB1CLK/UCA1STE" pin configured as a GPIO independently.
in principle yes. Using the P8.4 as GPIO or for other non SPI functionality is possible. Though, if in your setup there should be scenarios where it becomes necessary to avoid collisions between the Masters, you will have to find a SW workaround to handle that.
In case using the MSP430F5659 as the only SPI master, this is of course possible without limitations in the 3 pin mode.
Best regards
Peter
please let us know, whether you still need support on this topic. Many thanks in advance.
Best regards
Peter
