Hello
Explain the formula from demo code, please (V = (adc_code * (f_s/2))/(gain*7FF) + Bias). What is f_s and Bias in code? Where does it come from or how is it considered for the formula?
Hello
I can`t search it in document for MSP
the top level background of the formula is the intention to perform correlation of results. As DC portions of the signal would result always in positive correlation, the DC offset needs to be removed. This DC offset compensation is reflected by the BIAS in the formula.
Best regards
Peter
I didn`t inderstand the beginning of your explain "the top level background". Internet Translate didn`t give a normal translation
Unequal value of f_s have two demo code for SDHS...Why?
How consider or determine Bias?
/* --COPYRIGHT--,BSD_EX * Copyright (c) 2017, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ******************************************************************************* * * MSP430 CODE EXAMPLE DISCLAIMER * * MSP430 code examples are self-contained low-level programs that typically * demonstrate a single peripheral function or device feature in a highly * concise manner. For this the code may rely on the device's power-on default * register values and settings such as the clock configuration and care must * be taken when combining code from several examples to avoid potential side * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware * for an API functional library-approach to peripheral configuration. * * --/COPYRIGHT--*/ //****************************************************************************** // MSP430FR60xx Demo - SDHS sampling at 8MSPS and DTC transfer results to RAM // // Description: Configure the SDHS for stand-alone use (register mode) at 8MSPS. // Use the DTC to transfer the results to an array in RAM named "results" (located // in LEA RAM at 0x5000). Convert array back to input voltage using: // V = (adc_code * (f_s/2))/(gain*7FF) + Bias // where,adc_code is the ADC result(16-Bit Signed Int),f_s = .755V(Full-scale voltage), // gain = 10^(0.1/20)) = approximately 1, Bias = .9V, 7FF = 2047 // // ***NOTE: On TS-Board, remove JP14, put SIG on inner pin and GND to outer pin. // Valid input range is 600mV - 1200mV, as configured.*** // MSP430FR6043 // --------------- // /|\| | // | | | // --|RST | // | P1.0|---> LED // | |-USSXTIN // | |-USSXTOUT // | CH0_IN|<--- input signal // // Gary Gao & Matt Calvo // Texas Instruments Inc. // February 2018 // Built with IAR Embedded Workbench V7.10 & Code Composer Studio V7.3 //****************************************************************************** #include <msp430.h> #define OSCTYPE__CRYSTAL OSCTYPE_0 void HSPLL_init(void); #if defined(__TI_COMPILER_VERSION__) #pragma DATA_SECTION(results, ".leaRAM") #pragma RETAIN(results) int results[1024] = {0}; #elif defined(__IAR_SYSTEMS_ICC__) #pragma location=0x5000 __no_init int results[1024]; #pragma required = results #elif defined(__GNUC__) int results[1024] __attribute__ ((section (".leaRAM"), used)); #else #error Compiler not supported! #endif int main(void) { WDTCTL = WDTPW | WDTHOLD; // Stop WDT // Configure P1.0 as output for LED P1OUT &= ~BIT0; P1DIR |= BIT0; // Disable the GPIO power-on default high-impedance mode to activate // previously configured port settings PM5CTL0 &= ~LOCKLPM5; // Configure one FRAM waitstate as required by the device datasheet for MCLK // operation beyond 8MHz _before_ configuring the clock system. FRCTL0 = FRCTLPW | NWAITS_1; // Clock System Setup CSCTL0_H = CSKEY_H; // Unlock CS registers // Per Device Errata(CS12) set divider to 4 before changing frequency to // prevent out of spec operation from overshoot transient CSCTL3 = DIVA__4 | DIVS__4 | DIVM__4; // Set all corresponding clk sources to divide by 4 for errata(CS12) CSCTL1 = DCOFSEL_4 | DCORSEL; // Set DCO to 16MHz // Delay by ~10us to let DCO settle. 60 cycles = 20 cycles buffer + (10us / (1/4MHz)) __delay_cycles(60); CSCTL3 = DIVA__1 | DIVS__1 | DIVM__1; // Set all dividers to 1 for 16MHz operation CSCTL3 = DIVA__1 | DIVS__1 | DIVM__1; // MCLK = SMCLK = 16MHz CSCTL0_H = 0; // Lock CS registers //Setup SAPH Bias Register Controlled SAPHKEY = KEY; SAPHBCTL &= ~ASQBSC; SAPHBCTL |= CPDA; SAPHICTL0 = 0; SAPHKEY = KEY+1; //Setup the SDHS with register mode SDHSCTL0 = TRGSRC_0 | AUTOSSDIS_1 | DFMSEL_0;// Software trigger,Left, 2s complement format SDHSCTL1 = OSR_0; // OSR = 10 (80MHz/10 = 8MSPS). CS must set MCLK >= 8MHz. SDHSCTL2 = 255; // SMPSZ = 255+1 samples SDHSCTL6 = 0x19; // PGA Gain 0.1 dB SDHSCTL7 = 0xC; // MODOPTI = 0xC (80MHz PLL output frequency) SDHSDTCDA = 0x800; // DTC transfer data to start of LEA RAM SDHSIMSC = ACQDONE; // Enable acquisition done interrupt (after 256 samples transferred) SDHSCTL3 = TRIGEN_1; // Enable trigger SDHSCTL4 = SDHSON; // Turn on SD and start conversion __delay_cycles(640); // Delay for PGA worst case 40us settling time HSPLL_init(); // Initialize the HSPLL and wait for it to lock // Configure TA2.1 for 1/sec to trigger the pulse generation and toggle LED TA2CCR0 = 9400; TA2CCR1 = 4700; TA2CCTL1 = OUTMOD_7 | CCIE; // Enable output signal to trigger PPG, enable Interrupt TA2CTL = TASSEL__ACLK | TACLR | MC__UP; // Timer sourced from ACLK (VLO), clear timer while(1) { __bis_SR_register(LPM0_bits | GIE); // Enter LPM0 w/interrupt __no_operation(); // For debug } } // Timer A2 interrupt service routine #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__) #pragma vector = TIMER2_A1_VECTOR __interrupt void Timer2_A1_ISR(void) #elif defined(__GNUC__) void __attribute__ ((interrupt(TIMER2_A1_VECTOR))) Timer2_A1_ISR (void) #else #error Compiler not supported! #endif { switch(__even_in_range(TA2IV, TAIV__TAIFG)) { case TAIV__NONE: break; // No interrupt case TAIV__TACCR1: SDHSCTL4&= ~SDHSON; SDHSCTL5 &= ~SSTART; SDHSCTL3 = 0; SDHSDTCDA = 0x800; SDHSCTL3 = TRIGEN_1; SDHSCTL4 = SDHSON; SDHSCTL5 |= SSTART; // Start conversion break; case TAIV__TAIFG: // overflow __no_operation(); break; default: break; } } // SDHS interrupt service routine #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__) #pragma vector = SDHS_VECTOR __interrupt void SDHS_ISR(void) #elif defined(__GNUC__) void __attribute__ ((interrupt(SDHS_VECTOR))) SDHS_ISR (void) #else #error Compiler not supported! #endif { switch(__even_in_range(SDHSIIDX, IIDX_6)) { case IIDX_0: break; // No interrupt case IIDX_1: __no_operation(); break; // OVF interrupt case IIDX_2: // ACQDONE interrupt P1OUT ^= BIT0; // Toggle LED to show new cyclelll __delay_cycles(1000); __no_operation(); // Put breakpoint here to view results break; case IIDX_3: break; // SSTRG interrupt case IIDX_4: break; // DTRDY interrupt case IIDX_5: break; // WINHI interrupt case IIDX_6: break; // WINLO interrupt default: break; } } void HSPLL_init(void) { // Configure USSXT Oscillator HSPLLUSSXTLCTL = OSCTYPE__CRYSTAL | USSXTEN; // Set up timer to wait in LPM for crystal stabilization time = 4096 clocks for crystal resonator. // For 8MHz XTAL, 4096 clocks = 512us. Using VLO = 9.4kHz, wait 5 timer clock cycles = 532us. TA4CCR0 = 5; TA4CCTL0 = CCIE; // Enable Interrupt TA4CTL = TASSEL__ACLK | TACLR | MC__UP; // Timer sourced from ACLK (VLO), clear timer __bis_SR_register(LPM3_bits | GIE); // Enter LPM3 w/interrupt __no_operation(); // For debug // Check if oscillator is stable while((HSPLLUSSXTLCTL & OSCSTATE) == 0); // Output oscillator on pin HSPLLUSSXTLCTL &= ~XTOUTOFF; // Init PLL // Use the PLLM setting to get 80MHz output from our 8MHz input // Equation: PLL output clock frequency x 2 = input clock frequency x (PLLM+1) // Input clock frequency = 8MHz // Desired PLL output clock frequency = 80MHz // PLLM = 19 HSPLLCTL = PLLM4 | PLLM1 | PLLM0 | PLLINFREQ; //PLLM = 19, PLL input frequency > 6MHz // Power up the UUPS to start the PLL UUPSCTL |= USSPWRUP; // Wait for UUPS to power up while((UUPSCTL & UPSTATE_3) != UPSTATE_3); // Wait for PLL to lock while(!(HSPLLCTL & PLL_LOCK)); } // Timer A4 interrupt service routine #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__) #pragma vector = TIMER4_A0_VECTOR __interrupt void Timer4_A0_ISR(void) #elif defined(__GNUC__) void __attribute__ ((interrupt(TIMER4_A0_VECTOR))) Timer4_A0_ISR (void) #else #error Compiler not supported! #endif { // Stop the timer and wake from LPM TA4CTL = MC__STOP; __bic_SR_register_on_exit(LPM3_bits | GIE); __no_operation(); }
sorry, I'll try to use a simpler English.
top level background in this case means in this case >> main reason / main purpose
Best regards
Peter
Hello Gentlemen,
We've got an 12Bit ADC converter this generates an output of either
0...4095 (0..0FFF) or alternatively -2048...2047 (F800...07FF) depending on the output format and bit shift..
For exact format see SLAU367 on 22.2.3.4 / Table 22-1
One cannot use the full scale for signals with high slew rate. The reason: you need to leave some headroom as amplitude margin for the decimation filter. A good practice is to leave 3dB; this allows you to detect larger signals and turn the gain down are measure again. If you think you miss some resolution, then simply go for OBR=2(13Bit) or OBR=2(14Bit) see 22.2.3.4. With gain=1(0dB) the theoretical full scale = 750mVpp. This is then true for low frequency signal components. Be aware that the ADC has strong frequency characteristics, see the filter curves in UG. Theoretical full scale was mentioned since you cannot access the SDHS allone, you need to go through the PGA; this gets as closear value to gain=1 is 0.1dB; this is the reason why 755mV ...and on top you should leave the amplitude margin.
Input signals with high frequency components (>20%) show some attenuation. Example: take UG,SDHS-chapter 22; Figure 22-9. For a signal frequency at a quarter of the sample frequency you've got an filter attenuation of ~2.3dB @ OSR 20. / signals with half the sample frequency are attenuated ~9dB. The SDHA in our case is of low OSR but high filter order.
This ADC is a very well suited converter for a narrow band conversion with high dynamic range. It is directly suitable for single signals or narrow band signals as used in flight time measurements of pulse trains with nearly constant frequency or frequency sweeps of single frequencies, it is not directly suitable for frequency mixes of unknown composition. To make it an universal ADC a digital linearization filter is required that compensated the roll off.
I hope this demystifies some things
have a good day
Johann
PS: I forgot the bias.... The DC-bias is also amplified by the PGA therefore it is wise to decouple with a capacitor; IF DC-coupling is required use the bias voltage outputs of the 'FR6043 to provide the correct mid-voltage.
Sorry, muscle memory typo. fs = 1023 for 10-bit ADC and fs = 4095 for 12-bit ADC.
please let us know, whether you still need support on the original topic. In case you have other questions, please open new threads respectively. Many thanks in advance.
Best regards
Peter
