Hi Team,
I am working with a customer who has a design with MSP430F2272 and is experiencing a loss of flash memory. Whenever this occurs it is in a 512 byte segment. The failure usually erases the first or second segment of the program memory starting at address 0x8000.We came across this post which cites a noisy power supply and frequency outside of operating region as possible issues. The supply does not look noisy and run the part at 8Mhz after 5 seconds from startup and the voltage is at 3.3 volts. Are there any other potential causes of flash memory loss whether it is system level or software? Is there any possibility that ESD could cause this? I would expect this to damage a GPIO rather than memory though.Some of the devices are 7 years old but this recently occurred on a new device.
Thank you,
Garret
