Other Parts Discussed in Thread: ENERGIA,
I installed energia and tried to upload blink example for fun.
But I failed to upload the file. I got the error message like the following:
boost::filesystem::create_directories: 파일 이름, 디렉터리 이름 또는 볼륨 레이블 구문이 잘못되었습니다: "C:\Users\З?AppData\Local\Texas Instruments"
If this continues, please run fsclean or set TI_APPDATA_DIR to directory you have permissions to access
스케치를 업로드 하는 동안 에러가 발생하였습니다.
I guess that the path name has Korean language, but I do not know how to fix it.
When I installed CCS , CCS was automatically shutdown as soon as the program window was open.
I only succeeded to use EK-TM4C123GXL launchpad through Keil-C, but I have limited version, which allows only up to 32kB.
It seems that energia is very easy to go. So if possible, I try to fix the upload problem with energia.
