TM4C129XKCZAD: EPIOS Bus
Part Number: TM4C129XKCZAD
Is EPIOS a self clocking system or do certain lines (for optimum performance of the EPIOS bus), have to go to a clock input if (for example) one was interfacing between this uController and an FPGA? To put the question another way, do some of the lines of the EPIOS bus have specific functions in some modes?
  • Hi John,
     One of the supported modes by the EPI module is the general purpose mode which can provide clock to your FPGA.
    Below is the excerpt from the datasheet. Please refer to the device datasheet for details.
    11.4.4 General-Purpose Mode
    The General-Purpose Mode Configuration (EPIGPCFG) register is used to configure the control,
    data, and address pins, if used. Any unused EPI controller signals can be used as GPIOs or another
    alternate function. The general-purpose configuration can be used for custom interfaces with FPGAs,
    CPLDs, and digital data acquisition and actuator control.
    General-Purpose mode is designed for three general types of use:
    ■ Extremely high-speed clocked interfaces to FPGAs and CPLDs. Three sizes of data and optional
    address are supported. Framing and clock-enable functions permit more optimized interfaces.
    ■ General parallel GPIO. From 1 to 32 pins may be written or read, with the speed precisely
    controlled by the EPIBAUD register baud rate (when used with the WFIFO and/or the NBRFIFO)
    or by the rate of accesses from software or μDMA. Examples of this type of use include:
    – Reading 20 sensors at fixed time periods by configuring 20 pins to be inputs, configuring the
    COUNT0 field in the EPIBAUD register to some divider, and then using non-blocking reads.
    – Implementing a very wide ganged PWM/PCM with fixed frequency for driving actuators, LEDs,
    etc.
    ■ General custom interfaces of any speed.
    The configuration allows for choice of an output clock (free-running or gated), a framing signal (with
    frame size), a ready input (to stretch transactions), an address (of varying sizes), and data (of varying
    sizes). Additionally, provisions are made for separating data and address phases.
    The interface has the following optional features:
    ■ Use of the EPI clock output is controlled by the CLKPIN bit in the EPIGPCFG register. Unclocked
    uses include general-purpose I/O and asynchronous interfaces (optionally using RD and WR
    strobes). Clocked interfaces allow for higher speeds and are much easier to connect to FPGAs
    and CPLDs (which usually include input clocks).
    ■ EPI clock, if used, may be free running or gated depending on the CLKGATE bit in the EPIGPCFG
    register. A free-running EPI clock requires another method for determining when data is live,
    such as the frame pin or RD/WR strobes. A gated clock approach uses a setup-time model in
    which the EPI clock controls when transactions are starting and stopping. The gated clock is
    held high until a new transaction is started and goes high at the end of the cycle where
    RD/WR/FRAME and address (and data if write) are emitted.
    Yes. As mentioned the EPI can be configured for different modes: SDRAM, Host-bus and General Purpose modes. For different modes, different EPI lines can have different functionalities. For example, in SDRAM mode the EPI0S30 line is for CKE (clock enable) but in Host-Mode the same line is used for CSn (chip select) while in General-purpose mode the EPI0S30 is used as a Frame signal. So it depends which mode you select.
