Hi TI:
how can i re-compile the usblib and debug it?
I import a tivac rtos example, and i change some usblib code, i found it will not be recompiled?
Hi TI:
Hello Yao,
Yao Aili said:I import a tivac rtos example, and i change some usblib code, i found it will not be recompiled?
Did you import the usblib project into CCS? That is how to re-build the library after making changes, otherwise it will not applied to the .lib file. Alternatively, you can manually add all the usblib files to your project which may be better during development.
