I'm trying to configure the ADC on a custom board. At present, my code compiles but I dont see that the ADC ISR is being called. This is code ported from a nearly identical application (same processor, maybe minor clock differences). Relevant code snippets below. I'd appreciate any suggestions!
//////////////////Main Program/////////
int main(void)
//Initializations
PinoutSet();
sysclock = SysCtlClockFreqSet(SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_25MHZ, 25000000);
adc_configuration();
//Superloop
while(1){
ADCProcessorTrigger(ADC0_BASE, 0); //base, SequenceNumber
SysCtlDelay(LoopDelay * (sysclock / 3 / 1000)); //introduces 100ms delay - 3 b/c SysCtlDelay takes 3 clock cycles - 1000 b/c unit conversion
void adc_configuration(){
//Onboard ADC Configuration to read 3 external analog inputs on pins 13,14,15 and internal temperature
//read on sequence 0 with highest priority
//TODO - add measurements for heater voltage on pins 127/PD6/AIN5, 128/PD7/AIN4 and 12V rail 12/PE3/AIN0
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); //p.501 of Tivaware manual
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
//ADCClockConfigSet(ADC0_BASE,ADC_CLOCK_SRC_PLL | ADC_CLOCK_RATE_FULL,1);
ADCClockConfigSet(ADC0_BASE,ADC_CLOCK_SRC_MOSC | ADC_CLOCK_RATE_FULL,1);
while(!SysCtlPeripheralReady(SYSCTL_PERIPH_ADC0))
//ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_ALWAYS, 0); //Base, SequenceNum, Trigger, Priority
ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_PROCESSOR, 0); //Base, SequenceNum, Trigger, Priority
ADCSequenceStepConfigure(ADC0_BASE, 0, 0, (ADC_CTL_CH1)); //Base, SequenceNum, Step, Config
ADCSequenceStepConfigure(ADC0_BASE, 0, 1, (ADC_CTL_CH2)); //Base, SequenceNum, Step, Config
ADCSequenceStepConfigure(ADC0_BASE, 0, 2, (ADC_CTL_CH3)); //Base, SequenceNum, Step, Config
ADCSequenceStepConfigure(ADC0_BASE, 0, 3, (ADC_CTL_TS | ADC_CTL_IE | ADC_CTL_END)); //Base, SequenceNum, Step, Config
ADCReferenceSet(ADC0_BASE, ADC_REF_EXT_3V);
//ADCReferenceSet(ADC0_BASE, ADC_REF_INT);
ADCSequenceEnable(ADC0_BASE, 0); //Base, SequenceNum
ADCIntRegister(ADC0_BASE, 0, adc_int_handler); //Base, SequenceNum, ISR Handler pointer
ADCIntEnable(ADC0_BASE, 0); //Base, SequenceNum
void adc_int_handler(void) {
adc_int_counter++;
ADCSequenceDataGet(ADC0_BASE, 0, adc_buffer);
rail_voltage_24v = adc_buffer[0];
rail_voltage_5v = adc_buffer[1];
rail_voltage_3v3 = adc_buffer[2];
rail_voltage_24v_volts = ((float) rail_voltage_24v) / ((float) 0xFFF) * 3 * 9.635; //12-bit ADC, 3V reference, 9.635x divider attenuation
rail_voltage_5v_volts = ((float) rail_voltage_5v) / ((float) 0xFFF) * 3 * 2; //12-bit ADC, 3V reference, 2x divider attenuation
rail_voltage_3v3_volts = ((float) rail_voltage_3v3) / ((float) 0xFFF) * 3 * 1.330; //12-bit ADC, 3V reference, 1.330x divider attenuation
tiva_temperature = adc_buffer[3];
ADCIntClear(ADC0_BASE, 0); //base, SequenceNumber
