I am having difficulties configuring the ADC, Here is my code:
#include <stdint.h> #include <stdbool.h> #include "inc/hw_memmap.h" #include "inc/hw_types.h" #include "inc/tm4c123gh6pm.h" #include "driverlib/sysctl.h" #include "driverlib/gpio.h" #include "driverlib/interrupt.h" #include "driverlib/timer.h" #include "driverlib/adc.h" int FsSensor = 125000; int FsPotA = 40000; int FsPotB = 20000; volatile float Pot_A; volatile float Pot_B; const float conv = 3.3/4096; //0 - 3.3 volatile uint32_t avgTemp; volatile uint32_t TempC; volatile uint32_t TempF; void ObtMuestra(void); void TimerTemp(){ SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0); TimerConfigure(TIMER0_BASE, TIMER_CFG_A_PERIODIC); TimerLoadSet(TIMER0_BASE, TIMER_A, SysCtlClockGet()/FsSensor - 1); //40MHz / 125KHz TimerControlTrigger(TIMER0_BASE, TIMER_A, true); TimerEnable(TIMER0_BASE, TIMER_A); } void TimerPot(){ SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER1); TimerPot1(); TimerPot2(); } void TimerPot1(){ TimerConfigure(TIMER1_BASE, TIMER_CFG_A_PERIODIC); TimerLoadSet(TIMER1_BASE, TIMER_A, SysCtlClockGet()/FsPotA - 1); //40MHz / 40KHz TimerControlTrigger(TIMER1_BASE, TIMER_A, true); TimerEnable(TIMER1_BASE, TIMER_A); } void TimerPot2(){ TimerConfigure(TIMER1_BASE, TIMER_CFG_B_PERIODIC); TimerLoadSet(TIMER1_BASE, TIMER_B, SysCtlClockGet()/FsPotB - 1); //40MHz / 20KHz TimerControlTrigger(TIMER1_BASE, TIMER_B, true); TimerEnable(TIMER1_BASE, TIMER_B); } //ADC Config void ADCconfig(){ SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); GPIOPinTypeADC(GPIO_PORTE_BASE,GPIO_PIN_1); //CH2 GPIOPinTypeADC(GPIO_PORTE_BASE,GPIO_PIN_2); //CH1 ADCSequenceConfigure(ADC0_BASE, 0,ADC_TRIGGER_TIMER,0); ADCSequenceStepConfigure(ADC0_BASE,0,0,ADC_CTL_CH2); //PotA ADCSequenceStepConfigure(ADC0_BASE,0,1,ADC_CTL_CH2); //PotA ADCSequenceStepConfigure(ADC0_BASE,0,2,ADC_CTL_CH1); //PotB ADCSequenceStepConfigure(ADC0_BASE,0,3,ADC_CTL_CH1); //PotB ADCSequenceStepConfigure(ADC0_BASE,0,4,ADC_CTL_TS); //Sensor ADCSequenceStepConfigure(ADC0_BASE,0,5,ADC_CTL_TS); //Sensor ADCSequenceStepConfigure(ADC0_BASE,0,6,ADC_CTL_TS); //Sensor ADCSequenceStepConfigure(ADC0_BASE,0,7,ADC_CTL_TS|ADC_CTL_IE|ADC_CTL_END); //Sensor ADCSequenceEnable(ADC0_BASE,0); ADCIntEnable(ADC0_BASE,0); ADCIntRegister(ADC0_BASE,0,ObtMuestra); IntEnable(INT_ADC0SS0); IntMasterEnable(); } int main(void){ SysCtlClockSet(SYSCTL_XTAL_16MHZ|SYSCTL_SYSDIV_5); //40MHz TimerTemp(); TimerPot(); ADCconfig(); } void ObtMuestra(){ unsigned long ulADC0Value[8]; ADCIntClear(ADC0_BASE,0); ADCSequenceDataGet(ADC0_BASE,0,ulADC0Value); Pot_A = conv*(ulADC0Value[0]+ulADC0Value[1])/2; Pot_B = conv*(ulADC0Value[2]+ulADC0Value[3])/2; avgTemp = (ulADC0Value[4] + ulADC0Value[5] + ulADC0Value[6] + ulADC0Value[7])/4; TempC = (1475 - (2475*avgTemp)/4096)/10; TempF = (9*TempC)/5 + 32; }
I need 2 samples for each Potentiometer and 4 samples for temperature sensor, my issue is in the DataGet for the variable ulADC0Value:
The two Pot be in 0v and the samples of the sensor was 2000 (for example), so the array in the first interrupt was: [0,0,0,0,2000,2000,2000,2000], when I resume for the next interrupt I get the values move in the array like: [2000,2000,0,0,0,0,2000,2000], in every interrupt I get the values move in the array, so the convertions for the values of Pot_A, Pot_B, TempC and TempF change radically. What's going on?
I thought the [0] and [1] of the array was assigned to the values in channel 2. [2] and [3] to channel 1, and [4] ... [7] for the sensor.
