Other Parts Discussed in Thread: MSP-EXP432E401Y
We are working with the MSP-EXP432E401Y development board and CCS because we are interested in using the MSP432E401Y microcontroller in our product line. So far I have been looking at the out-of-box example. Our application is written in assembly so the end product will be primarily assembly code based.
I'd like to get information on how to configure and use the Ethernet Controller. The Ethernet requirements for our applications are very simple. It is a server. It receives a command (about 30 bytes) and sends a response (about 100 bytes) every few seconds.
What I'd like to find out is how to set the ip address (IPv4), gateway, subnet mask, & port# and any other parameters that will need to be set for my application to work properly. Then I'd like to know what bit to read to see when incoming data is available, and where to get the data that came in. And finally I'd like to know where I should put any outgoing bytes that will be sent in response.
Thank you so much for your answer,
Brad McMillan
