Tool/software: TI-RTOS
Basically I followed the example LoggerIdle setup example available here:
processors.wiki.ti.com/.../LoggerIdle_Uart
This presented a couple of problems. It appears that when this example was written there was an ability to use the .cfg to selectively disable Instrumentation. From the LoggerIdle_Uart example's .cfg:
UART.libType = UART.LibType_NonInstrumented;
This option appears to be no longer be supported. Futuremore I only want to turn off Instrumentation for the log data I am sending out a UART in the Idle task. To make this work right now I have to turn off all Instrumentation with:
driversConfig.libType = driversConfig.LibType_NonInstrumented
If I don't do this the log data I write out the UART triggers additional logging.
I really want to use your Instrumentation to analyse interactions with several other serial devices I have interfaced to the processor. Is there a good way to use the Idle task logging out a diagnostic UART port and leave the rest of the Instrumentation in place?
Roy Cooley
with InstrucmentIs there a way to turn
L
project's don in a ing there was a options Hi
