Part Number: DRV2604L
Hi Expert,
They found the difference output waveform by BEMF_GAIN setting.
Could you please let me know the reason of difference?
at BEMF_GAIN=0x03
at BEMF_GAIN=0x02
Muk
Hi Expert,
at BEMF_GAIN=0x03
at BEMF_GAIN=0x02
Muk
Hello Muk,
Well with the higher gain BEMF_GAIN value on top the closed algorithm is reading in actuator acceleration as larger than it should be causing it to overcorrect which then leads to next reading seeing too big of a drop in acceleration and tries to correct again and cycles through that loop trying to stabilize but never reaches it because that back-EMF amplification is too large for it to do so.
That lower picture with lower gain setting allows it to stabilize and output a consistent waveform.
Carson
Low Power Audio Applications
