Part Number: DRV8432
I am using DRV8432DKD.
In datasheet the mode select pin connection is given in section 9.4.4 as "It is not recommended to connect mode pins to board ground if 1-Ω resistor is used between AGND and GND".
but in EVM and application circuit mode pins are connected to GND even though the AGND and GND are connected with 1-ohm resistor.
Kindly, provide a clarification on connection of mode select pins,
Anjanaa
