MCT8316AEVM: How to use PWM input mode and Frequency input mode with MCT8316AEVM
Part Number: MCT8316AEVM
Other Parts Discussed in Thread: MCT8316A
Hello, I have a problem with rotating motor using MCT8316AEVM.  I was able to drive a motor with analog input and I2C input modes.  However, I could not start rotating a motor with PWM input and frequency input modes.  I used a function generator(FG) to send a signal.  I connected a positive pole of FG to SPEED_IN pin and a negative pole of FG to SPEED pin.   Could you tell me whether it is wrong or not?  Thank you.
    Thanks for posting your question in MD forum. Can you share the frequency of the PWM input signal generated from function generator? Is speed input mode configured to "PWM input mode (varying PWM duty cycle)" or "Frequency based speed input mode (varying PWM frequency)"? MCT8316A does not have "SPEED_IN" pin. Refer to the pin diagram below. If you are using the MCT8316AEVM, you should firstly configure the Jumper J1 (SPEED_SEL) to EXT and connect positive terminal of Function generator to EXT_SPEED test point and negative terminal to AGND. Jumper J1 can be located at the top left (below the 3 switches) of the MCT8316AEVM.
    Vishnu.
  • Mr. Balaraj
    Hello.
    Thanks to your useful advice, I successfully drove a motor with PWM input mode(varying PWM duty cycle).  However, I still could not drive a motor with Frequency based speed input mode(varying PWM frequency).  Initial conditions of function generator are followings:
    frequency: 10kHz
    amplitude: 2.2Vp-p
    offset: +1.1V
    duty cycle: 50%
    wave form: rectangular
    I look forward to hearing back from you.
    Thank you.
    Hideyuki
  • Hideyuki,
    In frequency based mode, motor speed varies linearly as a function of the frequency of the square wave input at SPEED pin as given in below screenshot. Input frequency greater than INPUT_MAX_FREQUENCY clamps the duty command to 100%.
    Please program the INPUT_MAX_FREQUENCY (located in DEVICE_CONFIG register) and vary the PWM frequency to observe change in motor speed.
    Vishnu
  • Mr. Balaraj
    Thank you for your reply.
    I thought I was able to fix motor rotational speed regardless motor load in Frequency based speed input mode.
    If that is impossible in Frequency based speed input mode, is there any way to fix motor rotational speed regardless motor load?
    Thank you,
    Hideyuki
  • Hideyuki,
    Moto speed should change with and without load when you change the PWM frequency after configuring the SPEED input mode to Frequency based speed input mode.
    Vishnu
  • Mr. Blaraj,
    Hello. I tried to find DEVICE_CONFIG register from "View Register Map", but I couldn't.
    Maybe I'm doing in the wrong way, but I don't know what I should do. Could you tell me how to change the INPUT_MAX_FREQUENCY located in DEVICE_CONFIG register?
    Thank you,
    Hideyuki
  • Hi Hideyuki,
    In the MCT8316A GUI homepage, click "View register map" and input the maximum frequency value in Hz in the highlighted box shown in below image. Please make sure you convert the frequency in Hz from decimal to hexadecimal.
    Vishnu
  • Mr. Balaraj,
    Thanks to your useful advice, I was able to drive a motor as I wanted.
    I really appreciate your cooperation.
    Hideyuki
