Other Parts Discussed in Thread: MCT8316A, MCF8316A
Hi Team,
I rotate a motor using external PWM signal. I usually rotate the motor as follows: 1. Turn on power supply, 2. Connect USB cable, 3. Load registers, 4. Disconnect USB cable, 5. Send PWM signals.
After I turn off power supply, I turn on power supply again and send PWM signals. In this case, the motor does not rotate. To rotate the motor, I have to connect USB and load registers again.
Is it because register setting is initialized after turning off power supply? If so, is there any way to memorize the register setting even after turning off power supply, because I want to incorporate MCT8316A in the device in the future?
Hideyuki
