For example, RESET_A and RESET_B is driven high to enable, RESET_C is driven low to block.
Thanks & Regards
Yale
Thanks & Regards
Yale
And, does DRV8312-C2-KIT support this operation?
Hi Yale,
The DRV8312 can support a full H-bridge mode. To have the device act like a H-bridge, you would, as you stated, set one of the half-bridges to HI-Z by pulling one of the RESET pins low.
For the DRV8312-C2-KIT should be able to drive a single brushed motor but this will require software modifications. You will have change/create software to only use two of the PWM inputs and send the correct high and low sequence.
Joshua
