UCC14140-Q1: Does not give the expected voltage
Part Number: UCC14140-Q1
This IC is used to give the secondary supply voltage ( 25 V) for the High side driver (SID1182K). The recommended values in the reference design mentioned in the Datasheet of this IC does not give the expected output voltage. Kindly check the attached Screenshot of the schematic and suggest the appropriate values to get the desired output voltage at the earliest.
Thanks in advance.
