Part Number: DRV8906-Q1
Hi team,
For the unused pins of DRV8906-Q1, do you suggest to connect to the GND or keep floating? Such as the nFault pin.
Ivy
Hi team,
Ivy
Hi Ivy,
The nFAULT pin is an open drain output. This means that it requires a pull-up resistor to function properly. The pin can be left floating if fault detection is not required.
What other pins are you wanting to connect to ground?
David
