Other Parts Discussed in Thread: UCC28C43-EP, TPS92410, TPS92660, LM3401, TPS92630-Q1, TPS40210-HT
I am looking for a open loop current mode controller for relay driver and I do not seem to find any without a inbuilt thermal shutdown?
Hello Binod,
I need to understand a few more things about your application so I can make a good recommendation.
Why is thermal shutdown not a desirable feature for you?
What is the intended operating temperature range of your end equipment?
What do you mean by "open loop current mode controller?" The DRV110 uses a current-sense resistor to implement hysteresis current control.
If possible, could you please share a schematic so I can better understand how you want to implement this in your system?
Its for down hole application where we are running up to 180 degree Celsius. We are running a electromechanical relay with Led driver HV9910B from supertex but it has some inherent issues. I see that TI has relay driver DRV110 but it has inbuilt thermal shutdown which prohibits from using in our applications. I cannot share schematic because of company policy. The driver is meant to run a relay like in DRV110. Let me know if you have any recommendations.
Binod
