I have a question about using the DRV8840.
I am planning to use the TI's motor driver DRV8840 and I am debugging it because there is a problem that the motor stops while driving the DC motor on certain machines.
The DRV8840 nFAULT pin on my board is connected as a floating state.
When I connect a pull-up resistor to the nFAULT pin to check the status of the FAULT pin (open drain output), it will not reproduce the symptom of the motor stop.
So I ask you to check whether the nFAULT pin should be left floating.
thanks,
TS
